Water in oil..cracked head?
Bguy
12-15-2002 20:13:45
I just got thru rebuilding a 430, had the head rebuilt, new rings etc. Cranked it up, I ran it for about 30 minutes and it put out light grey smoke which got worse as the engine warmed up. Pulled the valve cover and it had the white goo that can only mean water in the oil. I drained the oil and it looked OK, but it might not have ran long enough to build up there yet. I then replaced all fluids ran it again and had the same problem. Now my question is: is it the head, the block or a gasket? The head had a crack in it but the machine shop repaired this. There's not enough water gone from the radiator for me to tell any is gone. Are there any tests or ways to tell where this might be leaking?
mark
12-16-2002 10:03:38
 Re: Water in oil..cracked head? in reply to Bguy, 12-15-2002 20:13:45
You can pressurize by inserting an innertube from a bicycle or small motorcycle in place of the top radiator hose and inserting a few pounds of air. also works to test radiators that way.
Clooney
12-16-2002 06:06:49
Bguy, if the water is ending up in the combustion chamber & producing gray smoke it is more than likely in the head or head gasket. Unless the block has a crack in a cylinder wall your problem is more than likely the head or head gasket.
~Start by pulling the spark plugs & looking at them to see if you can figure out which cylinder is getting the water intrusion. If nothing on the plugs, try pulling both plugs after the tractor gets hot then pressurize the radiator [use low pressure 10 lbs or so] then after an hour or so crank the engine to see if water comes out of one or the other. You might even try putting air pressure in each cylinder through the spark plug holes with the valves closed & looking for air bubbles in the radiator.
~Drain the engine oil & pressurize the radiator [low pressure] then let it sit overnight to see if water is entering the oil pan area, if so, pull the oil pan & look in the crankcase to see where the water is entering from [if you had water in the cylinders during the first test it might just be seeping by the pistons rings]
~Once you figure out which cylinder is the leaking one, see if that matches up with the repaired head side, if so suspect a poorly repaired head. ~About all you can do is pull the head & have it pressure tested [hot if possible], look at the head gasket for areas where it wasn't sealing & look the block over real good. Most of the M-430's I have seen with block problems leak water into the oil & not into the combustion chamber.
~You did check for water in the air cleaner cup?
Bguy
12-16-2002 07:33:22
 Re: Re: Water in oil..cracked head? in reply to Clooney, 12-16-2002 06:06:49
Clooney, What is a good way to pressurize the radiator? Does NAPA or someone make a special cap? I can see how that would be handy to have.
Clooney
12-16-2002 07:55:57
 Re: Re: Re: Water in oil..cracked head? in reply to Bguy, 12-16-2002 07:33:22
Bguy, I have a Stant automotive pressure tester that I use a modified rubber cork shaped stopper that works good on odd radiators, [like tractors]. The price of a commercial pressure tester can be high & they probably won't come with the proper adapters to work with in an old Deere tractor radiator.
~You can use a cork or rubber stopper with a tire valve stem glued in, or even a direct hook up to your air compressor if you have a [good high quality] pressure regulator in the air hose & a pressure gage near the radiator adapter so you don't over pressurize the system.
