Help me ID this tractor
Zonie
12-15-2002 16:44:11
I'm trying to figure out just what model this John Deere is. the tractor has a 6 cylinder engine and runs on LP. it has a cat. 2 - 3 point hitch.
The LP tank has a date of 1966 on it. I'm assuming it is factory installed.
G-MAN
12-16-2002 10:24:50
 Re: help me ID this tractor in reply to Zonie, 12-15-2002 16:44:11
Definitely an early (below serial #201,000) 4020 LP. The single-wheel front makes it rather odd duck, as I don't believe I've seen one like that before. The LP also makes it kind of a rarity, at least in these parts - maybe they're more common down south. Are you considering purchasing it?
Zonie
12-16-2002 17:50:37
 Re: Re: help me ID this tractor in reply to G-MAN, 12-16-2002 10:24:50
No I'm not considering it. I just spotted it near my home for sale and I do have a friend out of town thinking about it.
This tractor definately needs alot of work, but the engine doesn't smoke!
Jim Hoy
12-15-2002 18:32:58
1966 sounds like 4020
Gman
12-15-2002 17:56:08
Zonie it's a 4010 row crop,maybe a 4020 lp row crop
chris
12-15-2002 17:03:37
It's a 4020, if somebody tells you its a 4010 there wrong, the pto lever is on the shifter side(right side as you're sitting in the seat). This tractor could be as new as a 1968.
Zonie
12-15-2002 18:13:21
 Re: Re: help me ID this tractor in reply to chris, 12-15-2002 17:03:37
Ok, now we know what model it is. Where would the serial # be located?
Thanks for the help
Zonie
Gary IN TX
12-15-2002 19:17:48
 Re: Re: Re: help me ID this tractor in reply to Zonie, 12-15-2002 18:13:21
Zonie,
It is a 4020 and the Serial number should be on the rear of the transmission case just above and to the right of the pto shaft. Another way to tell a 4020 from a 4010 is that the pto on a 4010 has 3 bolts that have to be removed to change shafts, the 4020 has a snap ring holding it in. 4010's and 4020's also have different hyd breakaway couplers as well. I know them when I see them but can't really think of how to describe them.
zonie
12-15-2002 19:22:46
 Re: Re: Re: Re: help me ID this tractor in reply to Gary IN TX, 12-15-2002 19:17:48
Thanks for the help
