JD A Governor Housing Gasket
JKC
12-15-2002 05:44:09
About to put the governor housing back on my 1944 JD A. Deere tells me they no longer make the gasket that seals between the housing and the crankcase. Is Ultra Black Gasket Maker gonna be OK to use here and will it do the trick? Any advise is appreciated. Thanks.
steve II JD4000
12-15-2002 06:56:36
 Re: JD A Governor Housing Gasket in reply to JKC, 12-15-2002 05:44:09
yeah it was hard to find.. my dealer just found the last one that they could find it was in Mn.
got it 2 week ago.
Clooney
12-15-2002 06:08:44
JKC, probably not. That gasket also controls the governor gear backlash. If no gasket is used the gears mesh could [probably will be] be too tight.
~I usually make the gasket from QUALITY gasket material. If poor quality or soft paper gasket material is used you risk an oil leak later down the road.
~I think 'Kevin' at [Farm Power Restoration]-610-845-3668- 9-5,M-F has [or had] those governor gaskets for about $7.00.
gwh
12-15-2002 07:31:46
 Re: Re: JD A Governor Housing Gasket in reply to Clooney, 12-15-2002 06:08:44
JD,Kevin still list the A-1193R (as RPA1183R)for $7.00 and it came with governor overhaul gasket set AA4293R which may(?)still be available from Deere. gwh
Clyde Scott
12-15-2002 08:57:58
 Re: Re: Re: JD A Governor Housing Gasket in reply to gwh, 12-15-2002 07:31:46
I just finished a rebuild of the governors on both my 36 and 46 A's and was able to get the gasket rebuild kits from Deere. They are still avaliable. The part number is AA4292R. This kit is fro SN 41000 until production end. JD parts online indicates it is still avaliable for $27.69 and include every gasket you will need to do the correct rebuild job. Hope this is helpful.
Clyde Scott - Moultrie, GA.
