3020 fuel gauge.
JD JACK
12-14-2002 19:20:07
Have 3020 gas early model fuel gauge reads F with key on all the time. Have 12v to feed side of gauge and 2.5v to wire at sending unit (wire is off). Ground wire, goes to E. Added temporary ground to sending unit still reads full. Should there be 12v at sending unit wire at tank? Didn,t check other side of gauge. Will be getting my variable resister from work, need to know if this is a 0-90 ohn circuit? I am thinking that sending unit has failed since gauge moves from F with open circuit and E with grounded circuit. Thanks JD JACK
