Jd 60 clutch
Seth Roemer
12-14-2002 15:13:06
The clutch handle on my 60 will not come back, we had a new clutch put in, and I steamed it off, could water have gottin there and rusted something up? Need some tips!! Thanks.....Seth
Clooney
12-14-2002 15:19:00
 Re: Jd 60 clutch in reply to Seth Roemer, 12-14-2002 15:13:06
Seth, we need a little more information to be able to help you.
~Was it working & just quit while in use? [or] Did it sit for a while then not work when you went to use it? [or] Did it act up right after the clutch was installed? [or] Is there some other factors we should know?
Seth Roemer
12-15-2002 10:04:49
 Re: Re: Jd 60 clutch in reply to Clooney, 12-14-2002 15:19:00
I have it at school painting it, I steamed it off , it worked before I took it apart, now it won't come back.
Clooney
12-15-2002 10:58:41
 Re: Re: Re: Jd 60 clutch in reply to Seth Roemer, 12-15-2002 10:04:49
Seth, if it worked before you took it apart & not after it was re-assembled there is something either assembled wrong or you have the 3 adjuster nuts too tight.
~First try backing off the 3 adjuster nuts 1 flat at a time to see if that helps. If not, make sure it is assembled correctly.
~Did you have the entire pulley off or just the clutch plates out of it?
Seth Roemer
12-16-2002 14:39:17
 Re: Re: Re: Re: Jd 60 clutch in reply to Clooney, 12-15-2002 10:58:41
The tractor was running last week, and drove it in the shop. I think it is rusted up....
