Hay rake help
Eric
12-14-2002 11:15:32
I have a 1952 JD 60 row crop. I want to create a "working set" of equipment from that same time period. I am working on a 555h plow, #5 mower, a relatively obvious disc choice, but am in need of a working or repairable JD rake. Pull type only. Also, if anyone can help with the disc identification that would be great. It has been said that it may be near impossible to do. Thanks for any help you can give.
JD
12-14-2002 12:41:49
 Re: hay rake help in reply to Eric, 12-14-2002 11:15:32
The side rakes of the time of the 60 would be the 594 or 851. The 594 is the older type rake.
There are lots of disks that will go good with the 60. KB, JB, KC, S single disk,GR offset disk
