Kevin, First off, sorry about your grandfather passing away...i know he must have been a great guy as well as knowledgeable man... Next, I am not a power-trol man by any stretch of the imagination, clooney is. My experience is from dual touch-o-matics hydraulics, so if what i lend in suggestions is wrong, someone please counter... If your power-trol has a plug for testing the pressure, and you have the right gauge, you can lock the lift arms and test your pressure [need to know the pressure range spec's]. Prior to doing this, clean/power wash all the old and dirty oil off of any area(s) that hydraulic fluid can leak: lines, connections, gasket areas, seal areas, etc. Lock/secure the lift arms, then, start her and increase the throttle to about 1/3, the gauge should read "0" because of no pressure, then slowly increase hydraulic control arm to about 1/3 of its capability, this should immediately show a reading on the gauge, if you are loosing pressure, the gauge should max out then start to decrease [keep everything else constant. [caution, do not exceed 25 seconds with the lift arms locked and the control arm in any lift positions]...during the 20 second period you are testing the pressure, if there are any seals or gaskets that are leaking, this test should show you where...look for any areas of fresh hydraulic fluid...then you know where you have to attack your problem... One final thought...if you do have a weak seal or something, performing this test might cause that seal or something else to become damaged further..this is something the pro's are going to have to evaluate re the risk's/rewards...a good tight hydraulic system will allow you to engage the full maximum pressure of the system while locking the lift arms and if left in this position too long, the pressure-relief valves will kick in and take the strain/pressure off the system if the operator does not via the control arms. good luck and keep us posted, tom
