John Deere M lights
Peggy
12-13-2002 07:32:13
My husband recently got a 1952 JD M and is now working on it, are there lights that go on this tractor? If so, how many, where do they go & does anyone have a source?
Bus Driver
12-14-2002 06:48:18
 Re: John Deere M lights in reply to Peggy, 12-13-2002 07:32:13
My 1952 M came originally equipped with a light mounted on the left front on a bracket protruding from just behind the grille. The light pointed forward. On the right (rear) fender, another light pointed forward. On the back was a clear light and a small red tailight.
Jod
12-13-2002 13:25:20
Mike gave good advice. This may also help. The brackets and the lights will have to be bought but for the front lights two s-shaped pieces are needed. If you get the right diameter rod (a common size) and have a friend with a torch they can be made. Borrow one and make a tracing for the person doing the bending.
Mike
12-13-2002 09:18:16
Yes, lights were optional on the model M and came in a variety of possible set ups. Most folks will put two lights on the front buy purchasing a remake of the original bracket's(about $30 each) If he's wanting to go back original, the original style 6V lights can also still be purchased for around $100.00. A third light can be mounted on the right rear fender along with an extension rod to illuminate the rear. Hope this helps!
Mike
