Is JD60 Manifold Gasket Same As On JD'A'?
TMAC
12-12-2002 16:20:28
The gasket in between the head and manifold is blown out. This JD60 is an early all-fuel with single induction like an 'A'. Are the gaskets the same? I have a 60's parts book so maybe the numbers will match up.
Brandon
12-12-2002 18:02:37
 Re: Is JD60 Manifold Gasket Same As On JD'A'? in reply to TMAC, 12-12-2002 16:20:28
The late A manifold from number 488000 onward is part number A2384R.
The early 60 all fuel prior to 6013899 is also number A2384R.
They match! Good luck with the change!
Brandon
