JD A gas tank question
Dale
12-11-2002 18:49:52
I need to know if a gas tank on a gas only A JD is the same as an all fuel tank. This is on a late 49 A. Thanks for any info.
Steve - IN
12-12-2002 02:58:19
 Re: JD A gas tank question in reply to Dale, 12-11-2002 18:49:52
Dale,
A's and most JD's seem to have been built by guys. If it had been done the way my wife or most women pack a suitcase - they could have crammed that second, little tank in the same space with the large tank used on a gas only version. As it is, guys had to use two different sizes of large tanks.
The downside of the female design might be that like a woman's suitcase - the JD A might have become an immovable object. -- just a little thought on the nature of life and travel over the holidays as applied to JD gas tanks.
Steve
Mike Aylward
12-11-2002 19:07:22
Dale, the fuel tank is the same on the all-fuel A tractors from serial number 488000 clear up to the end of production and on late A gas tractors up to serial number 655571 when the larger 18 gallon tank was adopted. The earlier tanks were 14 gallon. The 14 gallon tanks are more or less flat on the bottom and the later 18 gallon tanks have a small sump in the bottom. Hope this helps. Mike
