620 governor
Mike F
12-11-2002 18:29:23
Can somebody tell me if the tach plastic gear that goes though the housing (actual cable goes in it), does the end of the plastic gear rest on anything once it goes through the case? also what is the best way to remove the drift pin to get the gear for the hydro pump out? thanks .
Gordon
12-11-2002 20:07:48
 Re: 620 governor in reply to Mike F, 12-11-2002 18:29:23
The goes into a hole or boss in the gov case.The same angle as the housing is.I am not sure of witch pins two are doles the other a locking pin,that one should pull out.The plastic gear drivies the tac.
