JD-H POWER LIFT
GERRY
12-11-2002 11:22:55
CAN OIL FROM THE POWER LIFT LEAK INTO THE CRANKCASE ON A JD-H. I PUT OIL INTO THE POWERLIFT AND IT LEAK INTERNALLY. DO I NEED TO KEEP OIL IN THE POWER LIFT. IF I DO NOT PLAN TO USE IT.
Clooney
12-11-2002 14:00:19
 Re: JD-H POWER LIFT in reply to GERRY , 12-11-2002 11:22:55
GERRY, yes, it can enter through the pump to the governor seal, then through the governor to the crankcase.
