Clooney, transmission oil again, a learning mistake
Don c
12-11-2002 08:44:07
a learning mistake, i drained the first red. had a gallon pan to catch it. had to go away for a few hours, little did i realize the hole from the trans. to the first red. area was low enough to drain transmission also. slow but never stopped, thank goodness its cold her in pa. and gear lube runs slow. got about 3-4 gal. on floor, almost to the drain. what a mess, the cat has no litter now for its box. learn something new daily. thanks. Don c
Clooney
12-11-2002 13:58:17
 Re: Clooney, transmission oil again, a learning mistake in reply to Don c, 12-11-2002 08:44:07
Don, must be a numbered series. The lettered only drain a little engine oil from the 1st reduction area. ~Last time I used kitty litter for oil dry I had to do an oil change on the old barn tom cat. He must have thought it was a litter box & was covered with oil form one end to the other. [couldn't find his filter though]
Don c
12-11-2002 16:36:50
 Re: Re: Clooney, transmission oil again, a learning mistake in reply to Clooney, 12-11-2002 13:58:17
this tractor is a early JD 60
