830 Utility Power Steering
Shannon
10-18-2003 21:56:24
I just bought a 1975 830 3 cylinder utility tractor with a loader. It has manual steering, what will it take to convert it to power steering?
david val
10-19-2003 00:44:51
 Re: 830 Utility Power Steering in reply to Shannon, 10-18-2003 21:56:24
youl'l need an 8 piston hydraulic pump, a pressure control valve (priority valve). a 'T'eed pressure tube, steereing pressure tube, scv pressure tube, complete power sreering assembly (incl. steering wheel and hydraulic fitting). a power steering yoke shaft (steering sector), and a rockshaft flow control valve with spring.
there is a ball plug in the transmission housing underneath the prssure control valve that needs to be removed.
if not already installed, the bolt and washer that hold the steering arm to the steering yoke should be replaced with a 'f' grade bolt and a thick (1/2") hardened washer.
david
Scott
04-20-2004 13:57:10
 Re: Re: 830 Utility Power Steering in reply to david val, 10-19-2003 00:44:51
Have you ever had any problems with the power steering. I have a 830 and the power steering isn't too great. The lift works well. Do you have any suggestions. I was told by the previous owner that the fluid level had to be higher than the stick reading. If the tractor is idling, there is no steering at all.
Anderson
06-26-2004 16:19:25
 Re: Re: Re: 830 Utility Power Steering in reply to Scott, 04-20-2004 13:57:10
Clean the hyd. screen and replace the hyd filter. My 74 830 had a similar problem years ago and that fixed it. If the screen is plugged the power stearing pump will starve out before the main hyd pump will.
Shannon
10-19-2003 05:47:48
Thanks David,
That sounds like quite a bit of hardware. Any suggestions on where to purchase? Estimate on cost? Shannon
david val
10-19-2003 13:21:57
 Re: Re: Re: 830 Utility Power Steering in reply to Shannon, 10-19-2003 05:47:48
best place to get the parts is a scrap yard. most of the parts from other utility tractors like 1020, 2020, 2030 and later tractors, will fit. the tubing will need to be from a similar age 3 cyl. tractor. the pump and steering valve will probably need a going over.
david
