JD 410 Backhoe Loader
Steven B
12-09-2002 18:34:46
Can anyone tell me the weight of a 1978 JD 410 Backhoe Loader with factory cab. I have got a job to deliver one this weekend and my truck is rated just over 7 tons.
Thanks
Steven in Australia
karl
09-04-2004 15:56:22
 Re: JD 410 Backhoe Loader in reply to Steven B, 12-09-2002 18:34:46
i have jd 400backhoe without cab weight 28000
David - OR
12-09-2002 20:17:11
Deere's website lists a cabbed 410C at 14850 pounds operating weight. Extenda-hoe adds another 1000 pounds. 4WD adds 300 pounds.
The 1978 model may be a little bit lighter than the 410C but I suspect you will be over weight if you meant 7 tons. If you meant 7 tonnes, it is going to be close.
Steven B
12-09-2002 20:23:17
 Re: Re: JD 410 Backhoe Loader in reply to David - OR, 12-09-2002 20:17:11
Thanks David. My truck is rated to load 7350kg at 12900kg GVM so I should be ok.
Steven
