3pt hitch quick coupler for a 620
Greg
12-29-2003 17:52:06
Does anyone know where you can find a 3 pt hitch quick coupler for a semi mounted plow for a 620
MIKE HANLEY
12-30-2003 05:08:12
 Re: 3pt hitch quick coupler for a 620 in reply to Greg, 12-29-2003 17:52:06
Advice for plowing with a 620 and a semi-mount plow. First off the 620's load and depth control is in the upper link, as opposed to the 3010/4010 that had the load and dept control in the lower arms. The F-145 plow book shows a "mast" that was used when the plow was used on the 520/730 and the 2010 tractors so there was a link between the plow and the tractors load and depth control. We have two Quick coulpers and when we first got the 630 and the 3-16" F-145 plow (1976) we made our own homemade hookup off the upper hook on the quick coupler to the plow. We could't use the tractors upper link because it couldn't be shorted enought. We took a cheep after market upper link and cutout most of the center and the weld it back togther. However a semi-mount plow is closer to a trailer plow then a fully mounted plow and weather a factory mast of a homemade mast, that set up isn't as good as the load and depth control from the lower arms as on the 3010/4010. But being closer to a trailer plow, there are many places that load and depth control is not needed. The next year we got the 730 and when plowing we no longer used our homemade 'mast". But we couldn't use the factory upper link on the 730 as when coming through the bottom of a dip, the hook on the quick coulper would hit the plow. We went back to useing the upper link that we had shorted to give plenty of clearance between the hook of the quick coupler and the plow. We parked the plow in 1985 and now just dig with a coil shank digger and also use a disc. We get one quick coupler new in 1976 and a used one the next year. There are no loner made by JD but are now sold through JD dealers and are made by the "side line" company that is making some of JD's hay equipment.
