40 Standard
Dave
12-09-2002 07:07:19
I have a 1953 40 Standard the transmission will not shift when it gets cold I changed the greese last week it looked like tar it was so thick I put 90W back in after you let run about an hour it shift just find can anyone HELP!!!
How cold is it ?
12-09-2002 16:17:43
 Re: 40 Standard in reply to Dave, 12-09-2002 07:07:19
How cold is it where you are ? If really cold I think the owners manual calls for thinning out the oil.
Bguy
12-09-2002 07:27:51
Dave, Sounds like you have some water in the tranny somewhere that freezes and won't let you shift until the tractor warms up and everything thaws out. I doesn't take much water to do this. I would drain all trans, final drive and rear end fluids, flush out with diesel fuel and refill as per service manual. I would also recommend you change the crankcase oil at this time if you haven't lately.
