720D cylinder head question
Russ
12-29-2003 17:44:09
I am rebuilding my 720D head.The sleeves for the injectors seem to be in good shape,I had no leaks.My question is the o-rings r 1225r under the sleeve? If they are will vatting hurt these? If they have to come out is this hard to do and can I use the sleeves over. THANKS RUSS
Roger
12-29-2003 18:24:57
 Re: 720D cylinder head question in reply to Russ, 12-29-2003 17:44:09
I didn't know about the o rings until after the head was boiled at the machine shop & back on the tractor, that winter I looked in the radiator & NO WATER, it was all in the bottom of the crankcase, I pulled the injectors & sleeves, replaced the o rings & everything has been ok since. Hot tanking the head does eat up the o rings unless they were already bad, but the tractor was running before I overhauled it & there was no water getting in the oil then. The sleeves don't come out hard & I re-used mine, I welded a nut on a pipe tap to use as a puller.
RUSS
12-29-2003 18:30:39
 Re: Re: 720D cylinder head question in reply to Roger, 12-29-2003 18:24:57
Thanks Rodger you saved me a lot of trouble.
