51 B 6 volt to 12 volt Part II
Moto Head
12-09-2002 06:51:06
Mr. Clooney,
I went to Radio Shack and all I could find was a 10 watt, 10 ohlm resistor. That was the closest thing they had to a (3-5watt 10 ohlm) so I tried it. I put in the automotive ballast resistor we talked about (12v-6v) then put the 10w 10ohlm in between it and the distributor. I now have 5 volts at the dist, and the engine won't start or run. I need a few more volts.
Are the 10 watts too high?, or the 10 ohlms too high? Just point me in the right direction. I'll go find a 3-5watt 10 ohlm if you still think thats what I need.
Thanks in advance for your timely help...MH
WOW!!!
12-09-2002 16:39:58
 Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 06:51:06
WOW!!!! All this is hard to follow. Moto Head simply put chuck the Wico Dist. Pick up a Wico X series mag. and put it back to stock
6 volts. lots less headaches and can be done in the time it takes running around to Radio Shack
on a wild goose chase. It worked when it was made new in 1951 and probably lasted a lot of years trouble free. Just my two cents. This put back to original post will unfortunatly!!! set off a bunch of the hot heads.
Clooney
12-09-2002 11:17:20
Moto Head, I think you misunderstood the original post. That said to use a standard automotive ballast resistor IN SERIES in the distributor feed wire [that will be between 1-3 ohms depending on the resistor & it's temperature,,,,, ,THEN measure the running voltage to the distributor [at the dist post] at fast idle, & if ABOVE 8 volts or so, use a 10 ohm resistor [or more] hooked to the distributor post & GROUND [NOT IN SERIES] ~The idea behind that the 10 ohm resistor or resistors is TO ADD LOAD to the distributor post to increase the current flow through the ballast resistor therefore lowering the distributor voltage to what you need. If the running voltage is high you need to add more resistance in series, or increase the load.
~The proper way would be to change the ballast resistor resistance but that is hard to do with most ballast resistors being a fixed resistance so the easy way out is to increase the distributor load with an added resistor to ground.
~The problem with that Wico distributor is it draws less current than a Delco distributor due to an internal resistor & non oil cooled coil so a conventional ballast resistor probably won't drop the voltage enough without adding load. That internal coil in a Wico distributor won't take high 13-14 volts for long so you will need something. ~If that tractor came to you as a 12 volt make sure it doesn't already have a 12 volt internal resistor in the distributor.
John T
12-09-2002 12:26:09
 Re: Re: 51 B 6 volt to 12 volt Part II in reply to Clooney, 12-09-2002 11:17:20
Clooney, do you have any wico spec books that tell us what if any internal ballast that distributor used for a 6 volt system AND if they offered an optional larger ballast if used at 12 volts???? Perhaps it is already ballasted right and we dont know it??? The main thing I wish we could find out is THE CURRENT his coil and points are supposed to run at (you have any specs on that I sure dont????) and then if we knew his internal ballast resistance we can get him at exactly the right situation. Let us know Ol John T
Clooney
12-09-2002 13:07:33
 Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to John T, 12-09-2002 12:26:09
John, I might have something around somewhere but nothing I can just walk over to & look at. The 6 & 12 volt systems use different internal ballast resistors, but on the coil I really don't know. They seem to take the same replacement coil but there were more than a few original coils with different condensers used [probably to match the different coils] so even if I found a resistance number it could be wrong. I usually trash those Wico distributors, or if originality isn't an issue modify them to use an external coil. On the very few [Wico equipped] I have been involved with converting to 12 volts I used a Chrysler ballast resistor & added load to the distributor side with added resistance to ground & one has been in weekly use for about 15 years. Most of the others have been converted to a Delco dist over the years. The big problem is those internal coils are not oil covered or protected very well & the resistors are fragile so you don't have long to fool around with the resistance before you let the smoke out, & we all know what happens when the smoke is let out? ~He might have the internal 12 volt resistor [or a 12 volt distributor] if it came as 12 volts & is still running, so just measuring what's there might not work. I would guess if it won't start with 5- 6 volts at the distributor it is a 12 volt set up. I think he didn't measure it with fully closed points [or it has a 12 volt dist] or he wouldn't even have had 5 volts at the dist if it had a 10 ohm resistor [on a 6 volt dist] in the dist power wire in series.
nate
12-09-2002 15:25:25
 Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Clooney, 12-09-2002 13:07:33
clooney,
ive got a late styled b with a wico distributor, and am very interested in how you modify them for the external coil. im thinking about putting sold state ignition on this, but how would i wire it up to run on twelve volt with the external coil, with regular points. im sure if i could sort out all the imformation in these posts the last few days i could figure this out, but it sure is confusing.thanks
nate
John T
12-09-2002 16:43:06
 Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to nate, 12-09-2002 15:25:25
NAte, if youre considering an electronic ignition and high energy coil, I would toss that Wico and get a regualr delco distributor tehn post back or e mail for all or more lol then you ever need to know about electronic ignitions Ol John T Nordhoff
Clooney
12-09-2002 15:47:04
Nate, the external coil isn't that difficult. I use a different condenser with the stock points though. The coil is wired just like a Delco unit with the coil primary dist side entering the Wico & using the Wico points. The coil secondary wire must also enter to get to the rotor. [some drilling required]
~On the solid state ignition; I doubt you will find a hall effect unit to fit the Wico. How are you thinking of adding a solid state ignition? ~If you figure out how you are going to add the internal pick-up [points for a trigger usually don't work good on something that sits for long] let me know & I will try to take some pictures of a modified Wico dist [I must have one around here somewhere that I haven't tossed in the trash yet].
~You should consider using a Delco dist as they are much better for what you want...
Moto Head
12-09-2002 11:43:26
Ok, I understand, I had both resistors in series. I check and see what kind of resitior is already in the Wico, as I bought the tractor with a 12v batt already in it. I just picked up a 12ohm 3w and a 12ohm 5w to try also.
John T
12-09-2002 12:09:43
 Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 11:43:26
Good going moto, if you can actually get inside that Wico and determine its total internal resistance and see if it has an independant resistor in series with its coil (and its resistance), then we can tell you what size and wattage external ballast to add in series to be right on the money. Once you determine the resistances, the wattage ratign required to dissipate the heat is simply volts times amps. Good Luck John T
Moto Head
12-09-2002 12:58:32
 Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to John T, 12-09-2002 12:09:43
I just removed the side cover of the distributor,
(Wico XB) where the lead from the ignition switch goes. There was a winding of wire about 1" long about the diameter if a pencil. The winding was mounted on the back side of the cover. It measured 1 ohm resistance. Single strand wire covered in a white material for insulation, I guess. I could tell that the winding had gotten hot before. I'm guessing the material was asbestos since it showed no signs of heat damage. And of course it broke when I was pulling it out enough to see it.
Before that I got the voltage at the dist down to 9 volts with the engine runnning, (charging system not functioning yet)
I'll try to find out the resistance of the dist next.
Clooney
12-09-2002 15:29:42
 Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 12:58:32
Moto Head, unfortunately that resistance you measured isn't accurate. That resistor is a wound wire [probably nichrome] & the resistance changes from cold to hot. It gets hot when in use so the resistance would be different.
Steve - IN
12-09-2002 13:45:47
Moto,
Sounds like progress - except for the part where it broke. You might be good to go by just measuring the resistance from one primary terminal of the coil to the other.
Wonder how many years (decades) the guy you bought the tractor from had been running a 12 volt battery in it? You may have a 12 volt setup already.
You're talking about 3w and 5 watt resistors. They might get mighty hot mighty quick. Probably need higher wattage, Scotty.
John T - I should answer your questions instead of spinning yarns. I don't have any info on that distributor other than it's a rare bird indeed. Those in the know may well be paying the rent on that knowledge.
Steve
Moto Head
12-09-2002 15:36:40
 Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 13:45:47
I'm not used to using an analog meter. I put one lead on the coil primary output terminal, and the other on the positive lead, and read what I believe to be 5 ohms. I also did the same check on a universal 12 volt coil I have on a kohler engine and it read 6 ohms. Does this sound right?
I should have bought a DVOM.
Moto Head
12-09-2002 16:25:28
 Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 15:36:40
I guess now I need to back up a bit, and figure out what to replace that resistance winding with that I broke off inside the dist.
Thanks to everyone for all the input today!
Learned alot, and got a little accomplished.
I am going to get ahold of the guy I bought the "B" from and see if he put the 12volt batt. in it or if it was already in there...MH
Clooney
12-09-2002 16:52:20
 Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 16:25:28
Moto Head, after all this discussion I thought I would measure a Wico XB 6 volt internal resistor [had to look a while to find a non broken one]. I finally found one & it measured .995 ohms at about 68�F. I couldn't find a good coil [found a pile of frapped ones though]. I haven't fooled with a Wico XB dist innards in a few years so can't be sure on the coil resistance but 5 ohms sounds close. ~Here's my take on your present condition [take that for what it is worth]. Your internal resistor is kaput, you don't know what coil you have [there were differences even in production]. You don't know if you have the ignition switch resistor from the light switch to the ign switch that is used with the 12 volt XB distributor on the "A" [I was saving that until the other discussions slowed down a little] ~So here's what I'd do,,,,Run a jumper wire inside the dist to by-pass the resistor, set it up & use those 2 10 ohm resistors hooked together in parallel [side by side] then install the double resistor set in series [5 ohms] in the dist power wire,,then run the tractor & monitor the power post on the distributor & try to get it somewhere around 4.5-5 volts [add or remove resistance to get what you need]. If it runs & starts there see how high it gets with the charging system operating. If it will run & start at 4.5 to 5 volts you are good to go. If it won't start or misses under load up the voltage to 5-6 & try it again.
~When the distributor finally quits [it might never] but even good ones usually do, you can go to a Delco or add an external coil..... .....
Steve - IN
12-09-2002 16:02:31
Moto,
Now on sale at your local Radio Shack - DVOM's 19.95 or so. Guaranteed to work for 6 months or until you leave it out in the cold and the LCD bleeds to death. But much easier to read for any of us guys who past our mid 40's some time ago.
Your readings sound a little high to me, but they're relatively consistent - so I'd vote again that you have a 12 volt coil already.
Clooney's point is that the ohm device - resistor - doesn't obey Ohm's law the way it should when it gets hot (call the electron police). You'd have to run some juice through it for a while to see where it gets to when it's in a normal operating situation.
Steve
Clooney
12-09-2002 16:11:25
 Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 16:02:31
Steve, that LCD problem isn't just for cheap meters. I took my Fluke 87 to northern Mich. for cold weather testing use last winter & left it in the truck for a week & now it looks like a 30 year old TV screen.
Steve - IN
12-09-2002 16:32:34
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Clooney, 12-09-2002 16:11:25
Clooney,
Ha ha... I've got an expensive hulk of a Seiko that met with the same untimely end.
It's easier to laugh about it when it says Realistic on the label.
They used to spec the things to -20 C, but that seemed wildly optimistic.
Steve
John T
12-09-2002 13:42:45
Wow, sounds like youre really getting into the nitty gritty, but once done you will be fine if me and steve and the good ol clooney man and others dont wear down or not be smart enough to go on lol. What you described is a typical wire wound power resistor and dont worry too much if its ruined, we can eventaully get you the correct size of external ballast to add, because the only critical thing is the intended current rating of that coil and those points. If we cant find any factory specs, I would keep adding external series ballast resistance in series with the wire which connects to the power terminal UNTIL the point and coil current is around 2.5 to 3 amps or so max and/or she starts and runs good. I asked clooney and we still dont either really know at what current that coil is designed to run at, but if we did, we would give you a definite answer immediately. Not knowing and since you ruined the internal ballast, I would take an educated guess the external ballast now required is gonna be around 2.5 to 4 ohms, but I would start at about 5 and work it down until you had 6 to 7 volts at the Wico input (i.e. after the ballast) and current through and into the Wico not much over 2 to 3 amps absolute max. I dont think the ones you described are of sufficient power. They would need to be 18 watts for 6 volts at 3 amps. If you have several 1 ohms or .5 ohms you can add them in series to get what you need or two (same size) in parallell ends up being one half what either was. I probalby wouldnt go the other external shunt ballast route, but stick to the series only, but thats a whole other story. Let us all know. John T
Moto Head
12-09-2002 14:23:37
 Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to John T, 12-09-2002 13:42:45
When I bought the tractor it had a 12volt batt installed (neg ground). It was running good and has been, I probably have a couple of hours of run time on it now. How does Pos. or Neg. ground affect a distributor like this? or does it only affect the charging system? The charging system appears to be disabled also no indications on the amp meter of any chg or dischg.
Steve - IN
12-09-2002 15:44:17
 Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Moto Head, 12-09-2002 14:23:37
Moto,
I used to do that to old Brit iron - swap from pos to neg ground - so normal US type radios could be stuck in them. You swap the primary connections on the coil, the re-polarize the generator (then change the batt connections, of course, plus mess with eletric fuel pumps and other things a JD doesn't need to worry about). My guess is somebody has already breathed on your distributor, as it surely wouldn't run at all if someone had just swapped the batt terminals and hadn't done anything else.
If the green gods are really smiling, your charging problem may be solved by the generator repolarizing trick. Otherwise, sounds like the generator is acting up but at least the cutout side of the voltage regulator may be doing its job.
A SWAG kind of way to go at it is to measure the resistance from from pos to neg primary points of the coil. You're already got about 1 ohm external ballast with that thing you found inside. If the coil itself is 2 ohms or higher, my guess would be you've already got a 12 volt coil. If it's about 1 ohm across the coil, it's more likely a 6 volt job - and you're in for at least 2 more ohms of ballast to help it live longer. I'm voting it's a 12, not a 6.
..at least the plot thickens... good luck.
Steve
Clooney
12-09-2002 15:56:14
 Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 15:44:17
Steve, the 6 & 12 volt Wico use the same replacement coil with different internal ballast resistors & that internal resistor changes resistance with temperature.
Steve - IN
12-09-2002 17:00:31
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Clooney, 12-09-2002 15:56:14
Clooney,
Aaah..tricky, those guys. Sounds like the cost accountants and inventory reduction types won out over the field service guys with that design.
So with that much info, the next trick is somebody's gotta show up at the party with the part numbers for the two different ballast parts that could live inside the beast.
Failing that, maybe the most pragmatic idea is when Moto head said somewhere he was going to call the former owner and see how long that tractor has been running on 12 volts. Want to lay odds that it's been five years or more?
Steve
Clooney
12-09-2002 17:11:47
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 17:00:31
Steve, there is a difference in internal ballast resistors & the 12 volt "A" even used a resistor between the light switch & the ign switch to drop the initial current to the ign switch [the B was always 6 volt so it didn't have one] ~Knowing what I do about the XB distributor I doubt it was running for long with a 12 volt battery if the charging system was functioning 13-14 volts. Even 12 volts will kill those XB's in short order. All it would take is the ign to be left on [points closed] for a minute or so & poof.
Steve - IN
12-09-2002 17:55:09
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Clooney, 12-09-2002 17:11:47
Clooney,
You make it sound like Wico brought some Brits over from Lucas to do their all-in-one distributor design.
No wonder JD made a quick switch to Delco - and the info on those things is kind of swept under the rug.
So guess I'm back to where I was this morning with 4 or 5 1 ohms in series and now add another 1 or 2 to replace the broken one... and tweak it down until it starts / or up 'til it doesn't run. Have never tried your shunt to ground trick on a distributor - but it brings to mind a few off color limmericks, though.
BTW - if I remember correctly we used to have bunches of 25W bathtubs in quarter, half and 1 ohm flavors, so you can vary values with them in fairly small increments. Reason I remember that is we had to use them to tweak a badly designed data receiver in a set top cable box that was very heat sensitive. Nearly each one had to be heat soaked and tweaked on the 12VDC supply in the factory. What a fiasco that one was. Might as well have stuck a 20 dollar bill in each box and said don't call us when it breaks.
Steve
G Taylor....Lucas
12-09-2002 19:02:17
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 17:55:09
As they say about British automobile electical systems, "darkness by Lucas".
Charles
12-10-2002 07:38:26
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to G Taylor....Lucas, 12-09-2002 19:02:17
My favorite T-shirt, spotted at British Car Day in Annapolis, Md:
Drawing of a 3 position toggle switch;
"The Lucas Switch: Dim, Flicker, Off"
John T (Update)
12-09-2002 08:06:04
Moto, just in case you cant find the exact resistor needed, remember, if you put two of them in parallell of the same ohms, the net result is ONE HALF their value i.e a 6 ohm in parallell with another 6 ohm yields a 3 ohm, with the power the sum of the two. The 10 ohm you mentioned is way to high Im guesssing, but thats without the knowledge of what that Wico's DC resistance truly is. Also, the measuring of voltage drops is with the Wico's points closed of course, otherwise you have an open circuit in the wico and are groundign the ballast via your test lamp or voltmeter. Let us all know, maybe Steve or Clooney has specs or a wico distributor and can tell you its internal DC resistance?? Ol John T
Steve - IN
12-09-2002 07:59:50
Moto head,
10 watts should be fine, you want all the power or wattage handling you can reasonably get in those bathtub resistors so they don't get too hot.
If this is a 12V system to 6 volt coil, usually somewhere between 1.5 to 2.0 ohms is used to protect a 6 volt coil. If this is the Wico distributor deal - they already have some internal resistance, I thought. But play it careful and start out with 4 or 5 1 ohm bathtub resistors in series (they are usually rated at 10 to 25 watts) and move down until it starts.
Steve
John T
12-09-2002 07:45:02
Hi again Moto, I had to go way back and see what all myslef and clooney and Steve told you before lol. OK, I think it was decided you have a 6 volt Wico distributor (not a mag) and you wnat to run it on 12 volts right??? What I suggest is to add a ballst resistor in series with the wire feedign the Wico OF THE SAME DC RESISTANCE AS THE WICO DISTRIBUTOR ITSELF. In so doing, it will act as a voltage divider and drop 6 volts across itslef leavign the remaining 6 across the wico as it was designed for. As far as size and watts, I cant tell because I dotn know the DC resistance of the wico which is probably some sort of its own internal ballast plus a coil. My approximation is that total would be somewhere around 1.5 to 2 ohms or so, making its coil and points draw 3 to 4 amps, but thats only a guess. If so however, I would go buy at like NAPA or Tractor Supply or Rural King or Central Tractor and buy an ordinary WIRE WOUND BAKELITE ENCLOSED BALLAST which is around 1.3 TO 1.7 ohms and 25 to 30 watts. If you buy a Radio Shack, it would need to be at least 25 watts, because 6 volts at 4 amps is 24 watts of power it must dissipate. If you dont know the DC resistance of the Wico distributor, and you have to experiment at the right ballast, I still bet it needs to be somewhere between 0.8 to 1.7 ohms, but get it 25 or better 30 watts to be safe and not burn it up. Let us all know how you come out, it has been fun lending you a hand, and from a quick review of all earlier, I think you said the Wico had power to it (not a groundign kill switch) which made it a battery powered distributor, not a mag?? The right resistance to reduce its input voltage to 6 (as designed for) instaed of 12 is what I would sure try because its less expensive than a 12 to 6 Solid State Voltage Regulator. Good luck, Ol John T nordhoff
Steve - IN
12-09-2002 08:14:34
 Re: Re: 51 B 6 volt to 12 volt Part II in reply to John T, 12-09-2002 07:45:02
John T,
Sorry - when I started there was no answer there, but between fooling around and getting coffee, there was a better answer - yours - there by the time I finished.
Reading your post reminded me that this kind of experimenting when there where tons of bathtub resistors sitting around at work. Now I'd actually have to think about going out to buy the things at inflated retail prices.
Next we can make this real complicated by rigging up a fancy bypass circuit for Moto Head with a processor and a few sensors to decide when to switch some big resistor ladder. Then again, might as well work on new cars if we did stuff like that.
Havin' fun in the snow down there? We've got zero snow up here.
Steve
John T
12-09-2002 08:36:10
 Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to Steve - IN, 12-09-2002 08:14:34
Yo Steve, yep we got lots more snow than u guys but its about gone now. I like the term Bathtub Resistors cuz thats EXACTLY what they look like being all white and porcelain with that nice lil carved out opening where the wirewound resistor sets lol. I dont see any reason why, if he can measure the DC resistance of his Wico Distributor, he shouldnt simply add the exact same value in series for a ballast, because if it sees 6 volts at its input as original, its current draw is still 6 volts across its ohms and all should be fine. Even better, if we can get him to use the starter button with the extra lil terminal on its side (hot only when cranking) then he can have the full blown ballast bypass at start up like the later regular coil ignitions used. I have a full article on that very subject in this months Green Magazine. Take care, John T
Steve - IN
12-09-2002 09:30:28
 Re: Re: Re: Re: 51 B 6 volt to 12 volt Part II in reply to John T, 12-09-2002 08:36:10
John T,
Funny the jargon that starts up inside an organization that may not translate to the outside. We used to call 'em bathtubs. When dealing with Japanese and discrete transistor circuits we used to like those Darlingtons a lot just 'cause it was fun to hear them pronounce it! Once in a meeting on doing a C band receiver we were talking about a TI (terrestrial interference) bandpass filter when one outsider type guy poppped up and asked why Texas Instruments was causing problems.
Long ago I had an old Brit car with a bypass similar to what you describe - but done by Lucas (still the patent holder on the short circuit) with a diode for reverse protection. That diode died once and the starter wouldn't stop!
It's a good idea though, and should be a good article as nobody with a JD is messing with Lucas starters and solenoids. They'd frown upon such a simple and elegant fix in a machine today as you gotta have a uP with enough I/O to run a by-pass, also check the tire pressure pretty soon by Federal mandate, and do 101 other things as well to make it interesting.
take care,
Steve
