HELP!!, 38 BR rear left wheel locks-up in reverse? IDEAS?
Gary
12-08-2002 19:32:18
My BR left rear wheel locks up when I put her in reverse runs fine in all forward gears. The right rear wheel will spin in reverse but the left is locked up? Need ideas on what this may be? Thanks,Gary
Clooney
12-08-2002 19:45:26
 Re: HELP!!, 38 BR rear left wheel locks-up in reverse? IDEAS? in reply to Gary, 12-08-2002 19:32:18
Gary, I would suspect the L/H brake. If something came loose in the brake it could be self applying in reverse. If in doubt pull the brake assembly out & see if it still locks up. If it was something in the differential or forward of that it would lock for both sides. If not the brake, then maybe a tooth missing on the L/H bull gear or diff pinion gear.
Gary
12-08-2002 20:58:05
 Re: Re: HELP!!, 38 BR rear left wheel locks-up in reverse? IDEAS? in reply to Clooney, 12-08-2002 19:45:26
I will check the brake out,although the brake seems to work fine in foreward motion.I will get back with you with my findings on the brake. Hope I don't have to go into the gears :-( Thanks for the info! GARY
