Andy: The black specs of oil are coming probably coming out of the muffler. If you wipe your finger in there, it is probably slimy. This generally indicates poor rings or pitted cylinders. Been there done that (re-bore and pistons). Unburnt fuel from leaky injector tips could also be a contributing factor. The slime in the coolant could be there as a result of a leaky headgasket at the main engine or even the pony. The pony can get water in it's oil and vice versa through a bad water pump shaft or seals. The shaft is NLA from Deere, but Greg STevens has them. If one seal fails, oil in the water, if the other fails water in the oil. Ponies are $ to repair (been there done that), so be sure you have quality clean oil and pressure in that pony before you fire it up for an extended period. CLean out the oil return holes in both heads....they are very small and will gook shut easily). After sitting for a time, they tend to leak at the rear main seal, which means pulling the pony (not really a bad job). If the pony is ready to be cranked and ran, I would drain the diesel engine crankcase, and re-fill with diesel fuel and a new filter, and then motor the main engine for sometime to wash everything out. This will do no harm, and it called out in the book as a matter of regular oil changes (in fact they run the engine for 5 minutes....really cleans things up). Then you can re-filter and re-fill and know that you have clean oil. If anything shows up then, you'll know it when it came. It's also easier to tell diesel fuel from water at that point. I been into just about every area of both engines in the past year. They can be expensive to repair the right way. Frank-in-Tallahassee 70D // 855
