JD 2510 FIRING ORDER
PAUL DOWDEY
12-08-2002 07:18:38
JUST BOUGHT 2510 AND HAVE NO HISTORY ON IT. DOESN'T RUN. WHEN YOU TURN IT OVER IT SUCKS ON ONE CYLINDER THROUGH THE EXHAUST. IT IS A DEISEL. FOUND CLEARANCES ON INERNET TO BE .014 INTAKE .018 EXHAUST. IS THAT CORRECT AND WHAT IS THE FIRING ORDER? THANKS
chris
12-08-2002 20:44:35
 Re: JD 2510 FIRING ORDER in reply to PAUL DOWDEY, 12-08-2002 07:18:38
1-3-4-2
Gpower
12-08-2002 09:56:14
If it is sucking through the exhaust as you describe, it probably will not run very good, if at all. You have a stuck valve, or burned valve thats in bad shape. If you have the valve cover off, turn the engine over and see if all the valves seem to opening and closing normally. You can set the valves if you wish, 14 and 18 is right, or at least close enough to allow it to run. Sounds like yo have more problesm than that though.. Good Luck
