Jd #8 sickle bar mower
cam srigley
12-07-2002 16:57:31
i just bought a #8 mower (jd) will it work on my 44 jd model A? any info would be greatly appreciated. thanks cam
John T
12-08-2002 07:35:32
 Re: jd #8 sickle bar mower in reply to cam srigley, 12-07-2002 16:57:31
Cam, what type is your Number 8?? I think they made them both tractor mount, like the older No. 5 (with the mounting ears that bolted up on the sides of drawbar frame assembly) and pull type both?? I had and used one years ago but have slept too much since then to remember. I see no reason why any type you have wont work PROVIDED the mount is fore and aft sufficient for the PTO shaft to fit and work and theres clearance relative to the rear wheel. If pull or mounted, it probably requires a hydraulic cyliner to raise and lower the bar (I dotn think the 8's had any hand lift levers like some 5's), so does the A have hydraulic output couplers out the Power Trol to attach the cylinder hoses??? If not, they can be added and rememebr, you then have to select for them to be hot versus the rock shafts turning. Good Luck, Ol John T Nordhoff in Indiana
Craig- List of mower types..
12-09-2002 17:00:24
 Re: Re: jd #8 sickle bar mower in reply to John T, 12-08-2002 07:35:32
The No.8 is semi-mount just like the No.5.
No.8 mowers also had the cable (connected to rockshaft) or hand lift options in addition to the hyd lift option like the No.5. (No.5 also a foot lift option). I have the books that show all the lift options.
FYI...
No.9 is 3-pt hitch mount.
No.10 is side mount (mounts on side of tractor beside the engine)
No.11 is pull type, drop in the hitch pin and connect the PTO shaft.
What comes after that? 250, 350, 450???
cam srigley
12-09-2002 20:15:36
 Re: Re: Re: jd #8 sickle bar mower in reply to Craig- List of mower types.., 12-09-2002 17:00:24
thanks craig,
that was part of the info i was looking for,if you could pass on any more that would be great!
my #8 has the cable lift but no hand lever therefore i dont know what to do about a lift set up as there is no hydralics on my model a.
any ideas out there? thanks cam
Fudd
12-07-2002 18:10:02
Yup, it should work good. I would suggest you get the owners manual as it tells how to set it up correctly to your tractor. Have fun, I have a #9W.
