clutch rattle
Jim
12-29-2003 14:25:55
Looked at a 1946 "B" the clutck had quite a rattle disengaged, seemed fine engaged. is this adjustment, or badly worn?
Clooney
12-29-2003 15:56:11
 Re: clutch rattle in reply to Jim, 12-29-2003 14:25:55
Jim, that could be anything from the adjusting bolts hitting the pulley cover to loose & worn clutch plates, to a loose clutch driver on the crankshaft, to ?..
~Put the trans in neutral, then snap the clutch in, then try turning the clutch pulley both directions.. If you get any rotational movement in the pulley suspect a loose clutch driver [expensive repair]..
~If the pulley seems tight to the crank with the clutch snapped in that rattle probably isn't real serious..
[email protected]
