4239d power unit
Colin Baker
12-05-2002 20:33:12
Would anyone know how to set timing (flywheel& injection pump)so that I can remove pump for rebuilding. Thanks
WTW
12-06-2002 06:47:34
 Re: 4239d power unit in reply to Colin Baker, 12-05-2002 20:33:12
The reference marks to remove and time the injection pump are on the timing cover and front pulley. When aligned the engine is on top dead center No. 1 or 4. Remove timing window on pump after aligning front pulley marks and check to see timing marks are present and aligned before removing pump. If not you are on number 4. Rotate engine one revolution and realign cover and pulley marks, timing marks in pump window should then be present and aligned. Engine is timed (TDC) top dead center end of injection. Good Luck Dave W.
