620 main bearings
Mike F
12-05-2002 16:47:30
I recently took a 620 apart and I noticed on the main bearing on the clutch side that it has what looks to be two pusher bolts with a jamnut, any way , I twisted one off, and after I got it removed, I realized they are not to lift the main bearing housing, but what are they for? and should I worry about replacing the bolt? thanks.
Clooney
12-05-2002 17:11:47
 Re: 620 main bearings in reply to Mike F, 12-05-2002 16:47:30
Mike, you might be talking about the clutch fork stops. They control the clutch pulley & pulley brake application. See if there are witness marks on the brass clutch fork & if they line up with the broken bolt & the non broken bolt, if so that's what they are. You might be able to live without that bolt but the pulley brake won't work like it should.
~I that isn't the bolt you are referring to post back with a better description on the bolt & it's position on the main bearing housing..
