John Deere A stock Compression
DMoos
12-04-2002 13:02:48
Hi, I was wondering if anyone knows what a 1942 A stock compression would be. It is an all-fuel tractor, but somebody put a Gas manifold on it.
Any help would greatly be appreciated.
Thanks
DMoos
12-05-2002 06:20:06
 Re: John Deere A stock Compression in reply to DMoos, 12-04-2002 13:02:48
Thanks everyone, I was wondering what the compression was while running. For example is it around 6 to 1.
Thanks again
Duane
G-MAN
12-05-2002 08:08:31
 Re: Re: John Deere A stock Compression in reply to DMoos, 12-05-2002 06:20:06
The compression ratio is around 4.45:1. Gasoline "A"s have compression ratio of about 5.6:1.
DMoos
12-05-2002 08:39:18
 Re: Re: Re: John Deere A stock Compression in reply to G-MAN, 12-05-2002 08:08:31
Thanks G-Man. That helps alot.
Have a great Day!
Duane
G-MAN
12-04-2002 13:29:55
Compression pressure at cranking speed on an all-fuel "A" should be around 75 psi.
John T
12-04-2002 13:17:54
Sorry D, I dont have the factory stock compression specs in front of me. The changed manifold, of course, wouldnt affect compression. The manifold differences have to do with keeping the heat up to better vaporize heavier distilate type fuels, while gasoline only tractors didnt require as much. i.e., why they started on gas and ran it until the manifild warmed up. Ol John T
