B mag drive flange
ed b
12-03-2002 19:14:17
how do you get it off deere book says to use a special puller ????? thanks ed b
Clooney
12-03-2002 19:29:17
 Re: b mag drive flange in reply to ed b, 12-03-2002 19:14:17
Ed, I presume you have the shaft & gears out of the governor? It must be out to pull that drive flange. ~Lacking the proper puller, there are a couple of ways to get the flange off. The use of a bearing separator & arbor press is the best & safest. I have pulled those flanges off with a GOOD 3 jaw gear puller & some heat. Get the gear puller on & as tight as you can [they tend to slip when very much force is put on] then heat the flange JUST ENOUGH to allow it to move. Caution: don't use too much heat. You will have to fight with that darn spring while working with it.
ed b
12-03-2002 20:13:47
 Re: Re: b mag drive flange in reply to Clooney, 12-03-2002 19:29:17
what would be better acy torch or a propane torch thanks ed b ps clooney that bearing cup came out so easy i could not belive it
Clooney
12-04-2002 04:56:41
 Re: Re: Re: b mag drive flange in reply to ed b, 12-03-2002 20:13:47
Ed, I like an acetylene torch much better than a propane. The problem with a propane set up is it takes so long to heat something & during that long heating time heat transfers into the shaft, bearing & other parts where you don't want it. Using an acetylene/oxy unit you can heat it quickly & get it apart before the heat transfers very far. Heat it quickly & evenly around the drive flange but don't get it red, a little quick heat is usually all it takes.
ed b
12-04-2002 18:28:16
 Re: Re: Re: Re: b mag drive flange in reply to Clooney, 12-04-2002 04:56:41
thanks clooney ed b
