Cast Wheels????
Tugboat
12-03-2002 03:15:36
I'm about to remove the old tires and install new tires on my mobel "L" with cast wheels. I don't have any special tools to use on this job. Are the cast wheels easy to break? Should I be careful here?
Thanks, Tugboat
Dwayne
12-03-2002 15:39:29
 Re: Cast Wheels???? in reply to Tugboat, 12-03-2002 03:15:36
CAUTION, do not excede more than 30 psi to seat the beads. I have known several people injured and a few killed by trying to seat the beads on L an LA front wheels, the rim will explode if too much pressure is applied. you might have to grind on the inside of the wheel just enough to make it smooth. I have also had to grind some rubber off the tire beads. I use a liquid dishwashing soap for a lube, stay away from any petroleum based products, it will cause the tire to dry rot prematurely.
Clooney
12-03-2002 05:55:27
Tugboat, cast wheels can be broken if too much force or sharp blows are applied. As long as you don't go overboard with the force you will be ok.
~Use plenty of lube between the wheel & old tire as you break the bead [I won't post what I use here but it's something you put in your car weekly]
~Check both wheels for hairline cracks around the edges of the casting & if found don't pry or hit in that area or you could have a piece come out.
