John Deere STX 38 Won't Start
R. Yates
12-02-2002 17:05:50
I was mowing with my John Deere STX 38 (yellow deck) on about a 45 degree angle when my mower choked and stopped. I changed the fuel filter, plug, and cleaned the air filter and nothing. It turns over but won't start.
I think gas is only flowing into the carb but won't come out.
I verified that gas is filling up the Welbro Carb bowl and the float in the bowl is not stuck and the "Shut Off"? Solenoid is working when I turn the key On (it clicks and when it was out of the carb I grounded it and turned the key on/off and watched it move up/down) A local mechanic put some moderate air pressure into the base of the carb to try to blow out any crud that may have plugged the carb but it didnt work
Help. I'm not an advanced mechanic but I don't have the bucks to send this out (2 small, expensive kids). The leaves are piling up in my yard and the snow will be here soon too.
Any advice?
thanks
RY
tim
12-03-2002 04:01:11
 Re: John Deere STX 38 Won't Start in reply to R. Yates, 12-02-2002 17:05:50
try carb cleaner spray in carb crank engine if it starts prob in fuel sys ive seen fuel pump fill up with oil and not pump fully gl tim in wi
JD
12-02-2002 17:53:49
You say it stopped on angle. The seat has a safety stop switch. Maybe something is wrong with it.
