JD 730 Pony Start Transmission
Mark
12-01-2002 16:46:11
The man who rents my farm pulled the 730 to get it started. Now the H pattern shifting lever will only go into the gears on the right side of the H and they are the ones actually supposed to be on the left. (1st, 2nd, & 3rd). What is involved in getting into the transmission and is it something a handy guy can fix. Thank you for your help.
Mark
Clooney
12-01-2002 18:09:43
 Re: JD 730 Pony Start Transmission in reply to Mark, 12-01-2002 16:46:11
Mark, it sure sounds like the under/over drive popped out of engagement [probably due to a loose or partially engaged u/o shift shaft/fork/detent. The pulling & engaging the clutch probably was enough to pop it out of engagement.
~I will have to guess here, but it sounds like the under/over drive is now in low range with the shift lever stuck on the high range side.
~You will probably have to pull the shift cover [the one with the shift lever] & re-align the shift rails to allow the lever to pick the under/over drive shaft pocket back up when the lever is on the correct side of the quadrant. It would be a good idea to check the detent & detent locks on the over/under drive [farthest forward shift rail] to make sure they are functioning correctly..
Good job Clooney! Sorry about the post! Keep up the good work
12-01-2002 18:20:54
 Re: Re: JD 730 Pony Start Transmission in reply to Clooney, 12-01-2002 18:09:43
