Hercules or John Deere
JD
12-01-2002 08:41:00
I know John Deere used Hercules engines in some L tractors. Did they also use Hercules engines in some LA tractors?
How about the LU LUC LUW and LUS. I know about the Oil fill pipe. If its on a angle it was made be John Deere.
Brad in VA
12-01-2002 17:56:32
 Re: Hercules or John Deere in reply to JD, 12-01-2002 08:41:00
The model Y of which was the first concept of the L was produced with a NOVA two cylinder vertical engine. The model 62 and the first L's were made with the Hercules motors 1935 to 1941. In 1941 JD substituted their engine at around serial number 640000. Hope this helps
william H Black
09-04-2003 18:46:46
 Re: Re: Hercules or John Deere in reply to Brad in VA, 12-01-2002 17:56:32
We are restoring a John Deere L model tractor with the Hercules 2 cylinder engine. We are in need of the rod bearings or maybe also know as Babbit bearings. Do you know where we can purchase these bearings? John Deere isn't able to help so far.
Thanks
