Help need part
ed b
11-30-2002 17:52:25
i need a bearing cup jd # jd7408r its for the bearing on a differential for a 44 b deere says its obsilete but they still sell the bearing thanks for any help ed b
ed b
11-30-2002 18:14:15
 Re: help need part in reply to ed b, 11-30-2002 17:52:25
clooney i had new bearings pressed on the differential part#jd7246r i did not write the number of the bearing down but im shure its a timkin bearing i will try and pull the cup out of the quill next week (have 2 kids} and see if theres a # thanks ed b
Clooney
11-30-2002 18:29:35
 Re: Re: help need part in reply to ed b, 11-30-2002 18:14:15
Ed, be careful pulling that cup out of the quill, the quill is rather thin on the outer cover end & cracks easily. I usually run a bead of weld inside the cup & it will come out easily.
ed b
11-30-2002 18:34:44
 Re: Re: Re: help need part in reply to Clooney, 11-30-2002 18:29:35
clooney i dont weld could i put a steel plate in there to take some of the stress thanks ed b
Clooney
11-30-2002 19:06:51
 Re: Re: Re: Re: help need part in reply to ed b, 11-30-2002 18:34:44
Ed, I did that with a steel plate years ago & still cracked the outer cover. If you do use a steel plate use a large diameter insert to place the load as far out to the sides as possible.
~I have pulled those cups with a welder ever since..
ed b
12-01-2002 09:06:27
 Re: Re: Re: Re: Re: help need part in reply to Clooney, 11-30-2002 19:06:51
thanks maybe i can get my fatherinlaw to weld it let you know how it turns out thanks again ed b
Clooney
11-30-2002 18:00:19
Ed, is there a bearing number & name on the cup? If so, that is the way to find it. If it says {New Departure} it will be harder to find. I have found in a lot of cases New Departure bearings are hard to cross to..
