6 speed transmission
Shane
12-28-2003 19:32:49
My 1951 model B has started slipping out of gear. I have to strap the shifter to the steering post. I found some ball bearings and a piece of a race in the tranny fluid. Where should I start to dis assemble to search for broken bearing?
Clooney
12-29-2003 08:18:54
 Re: 6 speed transmission in reply to Shane, 12-28-2003 19:32:49
Shane, there is no telling where that bearing & race came from.. That slipping out of gear problem isn't a good sign though..
~Probably the place to start is to pull the top trans cover, then reach down in & see if there is excess movement in any of the trans shafts..
~Before you are done you will probably have to remove the shifter shafts, L/H gear cover & the 1st reduction cover, pulley, & 1st reduction gear.. If you haven't been into a 2-cylinder trans before you really should get a manual [or at least an I & T manual].
~You have to start somewhere & that would be with the top shifter & cover..... ..
[email protected]
Stuart
12-28-2003 20:44:10
I am guessing you have to tear it all the way down. You might try pulling off the side covers and take a look.
Your best bet would be to ask Clooney, He will know the answer
