I brought home the B today!
Lynn Kasdorf
12-28-2003 19:09:12
third party image
The B that I posted about a week ago followed me home today. The seller said that for various reasons it woudl be best to get it outta there today.
The right front tire was flat, and the left rim was tireless. So, I picked up 2 5.50 x16 tires and tubes. Alas, I misread the tube box and had to return the too small tubes I bought. Back to the store. The only 16" tube available is a 11.0 x 16, so I figured I could stuff it all in there.
After much hassle, my neighbor and I finally got the too-large tube and tire mounted. We decided that we could get it home on one good tire up front.
We towed it with his truck and a long chain. I drove the tractor and rode the brakes lightly on downills and levels to take up slack. When we got home (1 mile away), the brakes were hot! What a hoot, riding up there. I can't wait to get this cutie running and someday fully restored.
It does appear to have Powr-Trol, as there is a lever to the left of the seat, and not the 2 round pedals. I sure hope this is the case, as I plan to mount a 3 point hitch. It does not Roll-a-matic front (whatever that does).
A couple things strike me a great ideas. It looks like the brakes and the clutch would be super easy to service on this tractor, as they are external. What a great idea.
So, I plan to rebuild the carb, redo the ignition, and get it running asap. Repainting will have to wait a bit.
Question- should I keep this 6v with the generator? Or go 12v with and alternator. Do the old 6v systems work ok? Also, what about a solid state ignition system? I put one on my Ford 650 and absolutely love it. I'll post more pics and the sn tomorrow.
Yay! I've joined the green club!
CJDave
12-29-2003 18:51:09
 Re: I brought home the B today! in reply to Lynn Kasdorf, 12-28-2003 19:09:12
GREAT TRACTOR, Lynn; you won't be sorry for buying it! We bought a 1952 "A" which was in a lot of ways a mirror image of your "B" in that it was basically OK, but had been parked quite a while. It leaked transmission oil like MAD out of every seam on it....especially the axles. When we finally got around to draining the cases, there was THREE EXTRA GALLONS of condensate water in them. The water had floated the oil up and out of the axles. Once we got the oil changed and at the right level.....it quit leaking. Be ready when you unscrew those gearcase plugs.....chances are it'll be a real brown mess!
gary
12-29-2003 18:18:19
Lynn,
One thing that (I don't think) anyone suggested was to change all the fluids...transmission and rear, motor oil, oil in rock shaft, etc. Man that is important!
Good luck,,,you are hooked!
Gary
Dennis
12-29-2003 09:01:59
Lynn,
I went back to the original photos that you posted on this board last week and double-checked the hydraulic lift housing. As I posted before, you do not have Powr-Trol,you have Power-Lift. The casting # on the lift housing is A1430R which is a Power-Lift housing. Since you don't have a foot pedal but a hand lever instead, someone has obviously modified the control linkage under the battery box. I would suggest that you post a question about using a 3-pt with a Power-Lift system and see what experience others have had with that system.
Dennis
tom
12-29-2003 06:25:12
Lynn,
Here's some advice from a 1 yr green man with "0" prior mechanical experience...
Keep the old [orig.] electrical system and do the following:
1). Take the generator off, clean it and have the brushes, wires, armature and coils checked-out...anything bad, replace it
2). Examine all of your wiring and anything that is old, cracked, etc...replace immediately...
3). Test the ign. switch, if anything not working real well, take apart and clean the contacts...make sure your Ammeter is working...
4). Make sure your spark plug wires/caps are in great shape, if not, replace...of course, get new plugs...
5). Have the coil checked...if there are any cracks, breaks, etc...replace immediately
6). Assuming a distrib., replace the points and condensor and rotar...if any have a great physical inspection, your call on keeping...make sure she's timed correctly [get manuals]
7). Have your starter examined and tested, then do the same as the generator..
8). Have the battery checked or replace it, then get new cables to spec, and clean all the contacts real well and ALWAYS KEEP CLEAN...
If you do all of the following real early [you will do all of these sooner or later], your electrical trouble shooting problems will be almost a mute issue...if you not getting or maintaining a good spark and not keeping her charged...it is always a pain...
Hope it goes well and as the saying goes "you can pay her now or pay her later"...
good luck,
tom
Stan - Florida
12-29-2003 03:42:58
Lynn,
It would probably be a good idea to call Deere at 1 800 522-7448 and order a Parts Catalog (PC-330) and a Service Manual (SM-2004). Depending on how familiar you are with the Model B, an Operator's Manual (OM-R2005) might be in order.
I & T shop manuals are good, too, but I've found that, for an amateur like myself, the Deere manuals are more complete and understandable. Others may disagree.
Our '52 B was my favorite. Good luck!
ChuckW
12-29-2003 04:17:32
 Re: Re: I brought home the B today! in reply to Stan - Florida, 12-29-2003 03:42:58
have restored 4 of these...found the brakes the first thing to rebuild as this will keep you out of all kinds of problems. They can be rebuilt on the tractor or off. Most of the time the cams, pins are frozen. Takes heat, patience to rebuild. Good luck on your project, if board can be of assistance please advise. Oh by the way I converted mine to 12v but used JD generators off A's to look original, left 6 volt starter, no problem. Starts about 500% better.
CLW
12-28-2003 21:57:11
Lynn, you might try fresh gas and new plugs. A good batt. and it may just start. I have heard of tractors sit outside for years and were started by doing just that. Change the fluids and give it a try. You can check the charging system when you get it running. I am of the old school that says if it ain't broke don't fix it. The only problem with the 6v generator is if you only run the engine at slow speeds it may not keep the batt. charged but if you use the tractor in normal work conditions it won't be a problem. Let us know when you get her going and enjoy your B. Welcome.
P.S. the Roll-o-matic is a unit on the front pedistal that lets one tire stay on the ground while the other tire can roll over a 4 in. rock. It helps to keep the steering wheel in your hands if you hit something the tire can step over.
CLW
CLW
