730 D camshaft
Scott 730
11-27-2002 18:27:36
My old cam has casting # R20209. Which other castings would be useable in this engine?? I know there are several that will work. I just need to know which ones I can use.
G Taylor
11-28-2002 04:32:55
 Re: 730 D camshaft in reply to Scott 730, 11-27-2002 18:27:36
Another used cam will be worn as much or more than you old cam. Plus the lifters will have gotten mixed and not mated back with thier origional cam lobes. Restorers are willing to pay thousands to rebuild an engine but the results is often low on power/rough idling. Even more so on a diesel as the injection pump also works off cam lobes. A cam and lifters can be trued up for the cost of a set of rings. The late 720's and 730 have an anti reverse cam with odd shapped injector lobes.
