Height of 3010 thru 4020 rigid rollbar
BigMac
11-27-2002 10:30:23
Can someone out there with a 3010 thru 4020,that has a rigid 2 point rollbar, tell me the measurement from the top of the axle housing(bottom of mounting plate) to the top of the roll bar.
I want to add one to my 3010 but need to see if will clear the door opening.
Thanks,
BigMac
john2510-3020
11-28-2002 10:11:57
 Re: Height of 3010 thru 4020 rigid rollbar in reply to BigMac, 11-27-2002 10:30:23
Oh opps sorry didnt read all your post before i answerd, i gave you the whole height of tractor from ground to top of canopy. Measurements from axle housing to top of canopy is around 60-70"s hope this helps you better now.TTYL!!!
john
newgen
11-28-2002 09:48:44
BigMac I just went out to the shed and checked on my 4020-the measurement you need is 70". Hope this helps.
BigMac
11-28-2002 12:56:59
 Re: Re: Height of 3010 thru 4020 rigid rollbar in reply to newgen, 11-28-2002 09:48:44
Newgen,
Thanks for the measurement and your time. I appreciate it.
BigMac
john2510-3020
11-28-2002 06:58:26
Hi BigMac, we had a 2510 w/ roll guard and it was just about 3"s shy of hitting the top of a 9' tall door. So that would make it around 8'8" or 8'9" tall then right? Since a 2510 is the exact same tractor as a 3020 just diffrent engine these dimesions should work for you. Mine sat on 15-5-38's and 7.50-16's on front plus had a home made extension on the exhaust to get it above the canopy. I hope this helps you.
John
John
11-27-2002 19:08:01
My 4020 with 18.4-34 tires and the roll-bar/canopy will fit in our 10' garage doors with little room to spare.
BigMac
11-28-2002 03:08:28
 Re: Re: Height of 3010 thru 4020 rigid rollbar in reply to John, 11-27-2002 19:08:01
John,
Thanks for the reply but I need an actual measurement from the top of the axle housing to the the top of the rollbar.
My 3010 sits on 15.5 X 38 rears and 7.50 X 16 on a wide front. It probably sits higher than your 4020.
I have already had to cut the exhaust extention to get it in the barn.
Thanks.
BigMac
Gary in TX
11-27-2002 15:17:15
I am not sure of the measurements but I had one on the first 4020 I had and it fit in under a door opening of approx 105 inches
