JD H flywheel
JRH
11-27-2002 09:18:02
I have a '39 H. It seems the flywheel on my '39 is smaller then the one on my neighbors '42 H. I haven't compared them side by side though. Did JD use differant flywheels on these tractors. Both hand start. Thanks for the info, John
Paul from MI
11-27-2002 20:07:06
 Re: JD H flywheel in reply to JRH, 11-27-2002 09:18:02
You will find a lot of differences between your 39 and later H's. 3 bolts in L.H. cambearing housing, external oil line to L.H. cam bearing, High shift tower, many internal changes to transmission, actual shape of front wheel castings, etc.
L.O.L. Paul
Clooney
11-28-2002 04:25:58
 Re: Re: JD H flywheel in reply to Paul from MI, 11-27-2002 20:07:06
Paul, that external cam bearing oil line was a kit offered to correct a low RPM lack of oil to the cam bearing. It wasn't specific to the 39 but certain parts were due to the cam bearing difference.
Clooney
11-27-2002 09:23:26
Jrh, yes the 39 used the same P/N flywheel but it was a narrower than the 40 & later. The shift tower was also higher & the muffler was shorter on the 39.
Bud
11-28-2002 20:22:29
 Re: Re: JD H flywheel in reply to Clooney, 11-27-2002 09:23:26
JD H question. I have a chance to purchase a 41
H but, I am concerned about a wining in the rear end. Sounds like square cut gears. Is this normal for an H.
Clooney
11-29-2002 04:27:39
 Re: Re: Re: JD H flywheel in reply to Bud, 11-28-2002 20:22:29
Bud, not really. The "H" is usually fairly quiet but like any straight cut gear trans can have some gear noise if there is wear present.
~What gear(s) does it make noise in? If in all gears is the noise the same in all gears or is it different from gear to gear? ~Maybe the trans/bull gear area is just out of gear oil or has the wrong weight/type oil in it.
