1950John Deere B
Ed LaVallee
12-28-2003 15:55:00
I am currently restoring a 1950 J.D.b,I am wondering how concerned i should be about cracks on either side of the flywheel?should this be repaired?Also,the lower section of the carb.was hanging off,the threadedpiece is sheared off!can this be repaired or is this carb. for parts only now?
Clooney
12-28-2003 16:54:29
 Re: 1950John Deere B in reply to Ed LaVallee, 12-28-2003 15:55:00
Ed, those flywheel cracks can cause a flywheel failure & those heavy flywheel pieces can do a lot of damage to the flywheel cover [or worse].. With the correct procedure & enough pre heat & prep that flywheel could be welded but with a used flywheel for a B being quite inexpensive it would probably be more cost effective to just replace it..
~On that broken carb stem, that can be repaired but in most cases isn't a home type repair.. You might want to just send it out to place like Roberts Carb Phone: (712) 262-5311 {see link below}.. It's not a real cheap repair but a lot less than & different carb..
[email protected]
Ed LaVallee
12-31-2003 14:23:39
 Re: Re: 1950John Deere B in reply to Clooney , 12-28-2003 16:54:29
Thanks for the quick response to my questions.very much appreciated!!
old
12-28-2003 16:45:03
If the carb is broke off below the jets it can be fixed but if its up by the jets probably not, I got a rebuilt carb for my 35 B from Value bitl andit works good
