Generator Idiot light replacement for an idiot (4010)
Scott Trautman
11-26-2002 17:41:08
Okay, proof that I am an idiot.
I've got the new bulb.
I see the Generator (or oil) lamp assembly is spring loaded, but I can't quite figure out from what I can see how I get it open to replace the bulb. I DO have the service manual - and it assumes some smarts I must be missing.
Anyone care to help me out with this?
SMT
Craig
11-26-2002 20:45:19
 Re: Generator Idiot light replacement for an idiot (4010) in reply to Scott Trautman, 11-26-2002 17:41:08
There is the piece on top of the dash and the piece under the dash, with the spring in between them pushing apart. Just push both pieces together slightly and turn, I do not know which way. The two halves are held together in the same way that the light bulb fits the socket, push and turn. Does that help? It's a little tricky, comes apart a lot easier than it goes back together.
John in Md.
11-27-2002 03:00:48
 Re: Re: Generator Idiot light replacement for an idiot (4010) in reply to Craig, 11-26-2002 20:45:19
Turns counterclock wise on 3020,I guess they are all the same.
Steven M
11-26-2002 18:45:12
It's so easy to do but hard to tell you how. Hold the indicator lamp on the outside. With your other hand push in and turn. It just takes half a turn. Then pull
