JD 50 oil pressure
Brandon
11-25-2002 08:34:30
I started the 50 yesterday after it had been sitting for about three months. The oil pressure stayed just below M no matter what rpm. Has never done this before. Any ideas?? thanks, Brandon
Clooney
11-25-2002 09:54:25
 Re: JD 50 oil pressure in reply to Brandon, 11-25-2002 08:34:30
Brandon, you might want to check the engine oil for the presence of gasoline. Sometimes when sitting for long periods the fuel will leak past the shut-off & carb & into the crankcase therefore diluting the engine oil.
Chuck W
11-25-2002 08:47:41
the first thing to do is change the filter. You probably are not getting proper circulation. I would also suggest an oil change. You can adjust the pressure at the side.
