Broken bolt on thottle lever on 39 H
brian
11-22-2002 14:37:05
I was opening up the thottle on my H and the bolt broke off in the middle. any suggjestions????? ?
Clooney
11-22-2002 14:48:38
 Re: broken bolt on thottle lever on 39 H in reply to brian, 11-22-2002 14:37:05
Brian, what bolt broke off? Are you talking about the hand lever SET screw or a throttle stop bolt, or something on the governor or carb?
brian
11-22-2002 14:52:30
 Re: Re: broken bolt on thottle lever on 39 H in reply to Clooney, 11-22-2002 14:48:38
it was the full thottle bolt on the hand lever by the clutch.
Clooney
11-22-2002 15:13:24
 Re: Re: Re: broken bolt on thottle lever on 39 H in reply to brian, 11-22-2002 14:52:30
Brian, depending on how tight it is the casting & how much is sticking out, you can try to loosen it with the nut that's probably still there. If that doesn't work you will probably have to use vise grips, possibly heat & you might even have to drill it out..
brian
11-22-2002 16:13:18
 Re: Re: Re: Re: broken bolt on thottle lever on 39 H in reply to Clooney, 11-22-2002 15:13:24
THANK YOU!!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !
