G main bearings
KEN C.
11-21-2002 18:31:13
Got my crank turned today, rod journals, main journals were within specs.Local parts place says he can't get main bearings.Question being can the old bearings be put back in housing and be honed out to get back smooth at a machine shop, or need to keep looking for new bearings.This is on a 52 G model tractor. It has shims on main caps. Any suggestions are appreciated,thanks Ken.
Clooney
11-21-2002 20:00:54
 Re: G main bearings in reply to KEN C., 11-21-2002 18:31:13
Ken, I guess I don't understand, if your crank was within specs why did you have it turned? How much did they take off the journals? If you tell us how much was machined off maybe we can tell you if the original bearings can be resized to work with your re-ground crank. If by turned you just mean measured let us know.
~ We also have to know approximately how much wear is on the bearings & how many shims are still in them..
KEN C.
11-21-2002 20:40:48
 Re: Re: G main bearings in reply to Clooney, 11-21-2002 20:00:54
Sorry i did'nt make it clearer.The main journals were what he called just polished a little to get it clean. It had been sitting up for 15 to 20 years and had some surface rust on it.The old bearings looked good except for some rust patches from the crank. I'll have to count the shims and get back to you. Just wondering if they could be made to reuse are better off looking for new ones. I'll get the measurements and shim count and report back.Thanks Ken.
Ron Stephens
11-22-2002 05:05:50
 Re: Re: Re: G main bearings in reply to KEN C., 11-21-2002 20:40:48
I have a set of new John Deere mains for both sides. Would take $115.00 plus UPS for the pair.
Stephens Farms
Ron Stephens
3328 Rice Road
Dunkerton, IA 50626
319-822-7348
