Coleman lantern Fuel in G John Deere
Jason
11-21-2002 17:25:43
What is in Coleman lantern fuel? Because my G sure has alot of power when its pulling. Smells good too.
Sam#3
11-22-2002 06:26:21
 Re: Coleman lantern Fuel in G John Deere in reply to Jason, 11-21-2002 17:25:43
I read somewhere the base is naphtha which also the base of paint thinners. I can remember the term 'white gas' from many years ago. It was used in Maytag washer engines.
Steve - IN
11-21-2002 18:08:34
Jason,
Coleman fuel was gasoline before 1915 or so. Then they discovered that higher compression ratios required a mix of gasoline with more heavy carbon gasoline molecules, like octane, nonane, decane instead of the septane and sextane you find most of in lantern fuel or white gas.
What's important about that chemistry is that you're actually lowering your octane when you mix it with pump gas or run it uncut. Makes sense that a 6:1 engine will respond well to lower octane ratings, the bonus is that it smells good. The thing to watch out for is pinging as it will burn faster than pump gas. Then you'll either have to retard your timing or switch back to pump gas.
Steve
Steven M
11-21-2002 18:07:54
I think that is what they call white gas.
It's a Gas.
I can remember my grandpa telling me about White Gas and using it in a Gas lantern.
Chris
11-21-2002 17:48:57
I think its like what used to be distallite. Isnt that expensive though. Whats that stuff a gallon. Also Tractors that still have there all-fuel components still intact will lose horsepower when running on gasoline. Thanks
Jason
11-22-2002 05:50:08
 Re: Re: Coleman lantern Fuel in G John Deere in reply to Chris, 11-21-2002 17:48:57
I was expirementing and my dad told me to put a gallon in and see what it did. I think its about $3 a gallon. He uses it for ice fishing heat and light.
