JD60, rotary mower, 3-pt, wheel weights
David Cordray
11-21-2002 16:41:58
We own a 1955 row crop JD60 and want to purchase a rotary mower to use with it. Should we buy a 60" or 72" cut mower? We will be cutting vegetation like clover, bull thistles, prairie grass but no tree saplings. We believe that the tractor has the 801 series 3-pt and the top connector looks precarious. Should we try to upgrade/improve the 801 3-pt or buy an after market like the Saginaw County? Another question is we will be mowing on 13% slopes. Anyone know about adding front wheel weights and where to get them? Any help/advice would be appreciated. Thanks, Dave
Steve - IN
11-21-2002 17:41:09
 Re: JD60, rotary mower, 3-pt, wheel weights in reply to David Cordray, 11-21-2002 16:41:58
David,
The 60 will handle either the 5 or 6 foot mower with no problem here in the flatlands.
You're right, the 801 is a little willowy compared to a Saginaw. Prices on the 801's are stout, though. You could probably sell it for nearly enough to get a Saginaw and a used mower. One of the main functions of the top link with a mower is to keep the mower from flopping up. More mower, more worry; the Saginaw would probably be safer.
On slopes, they usually favor going with less width in the mower. Less leverage trying to pull you over. The 5' would be safer from that perspective.
Adding weight to the front would be a good idea in that you're lowering your center of gravity, plus counter balancing the mower. Rear weights would be a wash at best, I think, as nearly half the weight would probably be above the CG. You might be able to still get them from JD. If not, some of the bolt on weights for the front frame might work.
Also, if you keep the weeds down to a reasonable level, you could use a finish mower that has less leverage and therefore less worry on slopes than a bush hog type. But that requires more cutting more often, even if you set them to 4 or 5 inches, they won't want to deal with tall weeds.
good luck with it... and from experience, even mowing is fun on a 60.
Steve
Dave
11-24-2002 11:08:06
 Re: Re: JD60, rotary mower, 3-pt, wheel weights in reply to Steve - IN, 11-21-2002 17:41:09
Steve,
Thanks for the advice. Sounds like you own a JD60 as well. We have recently acquired ours. I must admit it is "catching" working with the old two cylinder tractors. Your fellow Hoosier,
Dave
ChuckW
11-21-2002 16:57:24
6' mower would be the best choice....I always use a chain to the top link to avoid binding when going in sways/low spots. With regards to weights, you can add about 75-100lbs with log chains in the tool box area...as to factory weights I don't have a clue.
Dave
11-24-2002 11:11:09
 Re: Re: JD60, rotary mower, 3-pt, wheel weights in reply to ChuckW, 11-21-2002 16:57:24
Chuck,
Good idea on the log chains. We have a few laying around we can use. Thanks for your help.
Dave
