Need help on 620 ?????
kelly
11-21-2002 15:23:05
i need help, my 620 will sometimes jump like it is fixin to take off. even when it is out of gear. any suggestions thanks in advance kelly
Clooney
11-21-2002 15:48:49
 Re: need help on 620 ????? in reply to kelly , 11-21-2002 15:23:05
Kelly, are you talking [in neutral] out of gear or just a [disengaged clutch] out of gear?
kelly
11-21-2002 16:16:20
 Re: Re: need help on 620 ????? in reply to Clooney, 11-21-2002 15:48:49
while it is in neutral. it is kinda scarey if you are standing next to the tractor.
Clooney
11-21-2002 17:01:54
 Re: Re: Re: need help on 620 ????? in reply to kelly, 11-21-2002 16:16:20
Kelly, if it's in neutral with the clutch dis-engaged I don't know what you have. If it's in neutral with the clutch spinning you could have a counter shaft idler gear bearing(s) going bad & the bearing(s) are momentarily locking the idler gear to the counter shaft. If that isn't it I don't know what you have. ~If that is the problem, [that's about all I can think it might be ] if you don't get it repaired pronto it will cost plenty when you do, as that shaft & idler gear are getting expensive.
~Unfortunately that counter shaft idler gear is very difficult to get at easily..... ..... ...
kelly
11-21-2002 18:42:41
 Re: Re: Re: Re: need help on 620 ????? in reply to Clooney, 11-21-2002 17:01:54
thanks a lot clooney I'll check all the bearings . kelly
