4010 won't start
JWhite
11-21-2002 13:37:10
I recently had the starter of my 4010 repaired and I put the wires back on the same posts as they came off. I took several pictures of the wires before removal. After re-adjusting the wires i finally got the gen light to come on when the key is turned. I have noticed the wire that goes from the starter to the push switch is not recieving any power. The service manual has a picture of a starter and makes reference to wire color. My starter doesn't look like the one in the book and not all the wire colors are on the tractor. I am trying to put a picture of the starter somewhere on this site. Which direction is the power go in reference to the switch (starter -> push switch OR push switch -> starter)? Is there something else that I am missing?
Steven M
11-21-2002 16:52:31
 Re: 4010 won't start in reply to JWhite, 11-21-2002 13:37:10
Hey! guys, The 4010 has the start safety switch up by the shifter controls under the dash.
When properly adjusted and with the transmission shift lever in a neutral position, the operating arm should be centered on the switch spring and the switch and bracket should be deflected forward 1/8 inch. If it is not loosen cap screws and relocate operating lever to correct.
This is from service manual SM-2039 John Deere 4000 series tractors.
The 3020 and 4020 and other have it on the side of the transmission.
G-MAN
11-21-2002 14:13:48
Try wiggling the shift lever while you're trying to start the tractor. You could have a nuetral start switch out of adjustment or going bad. It will be located on the RH side of the transmission case and should have two wires going to it. I don't have a schematic right here, but power should travel from the push button to the neutral start switch and then to the start terminal on the solenoid. That's where I would start.
JWhite
11-21-2002 13:55:47
posted 2 photos in the "Parts and Pieces" Gallery.
