730 puller
John
11-21-2002 13:34:32
Our family is kind of new to John Deere, we've always ran the other color green. Anyhow we ran into a 730 gas that we couldn't pass up. We we're wondering how many cubes and how many horses we could get. We want to go as big as possible! Can they be built to compete with power block JD G's?
Any help would be much appreciated!
G Taylor
11-22-2002 07:30:07
 Re: 730 puller in reply to John , 11-21-2002 13:34:32
A rowcrop 730 gas without any options might make it into the 7000lb class if you sit light on the seat. Until you learn a few tricks, try pulling in the so called stock classes in 1st or 2nd. Get the weight,balance,tire pressure, drawbar length etc ironed out 1st. The G can be squeezed into light classes to keep the HP per pound higher than the 730 when stock. The local 10,000lb class is usually won by a stock 620 creeping down the track in 1st gear.
