I'm bout to go nuts with this thing. Here's what I have: New wiring harness from Agri. ServicesGenerator brushes new and taken to Gen. shop to be checked, it is putting out 30 amps. New voltage regulator. Polarized it. New 8 volt battery-is that the problem? Painstakingly installed new harness. First tried it with old VR the amp gage would show a discharge with lights or ignition on, also lp solenoid. But when running the gage showed a slight discharge. Could not get it to move even with throttle wide open. ---Then went and got a new VR. Same thing, took the generator to a shop to be checked, he said it was fine and was putting out 30 amps. ---So --put the generator back on and re-polarized the VR. Cranked up-and gage went to showing about 15 amps dis-charge, then killed the engine and she went out of sight toward discharge, ran and disconnected battery cable and had a BIG spark. Let it sit for a while then touched the Battery cable back and no short now?? I am going to get out the diagram and go back over all the wiring harness, also I suspect the (NEW) voltage regulator may have been sold before - for someone to try. Also could the ignition switch be bad? It works fine on the ign.and lights.
