Can't Get Sediment Bowl Fuel Valve to Stop Flow
Mike
11-20-2002 19:12:37
I've got a gas-only 48 A. The sediment bowl has a two-way valve at the top for shutting off the fuel. Well, the fuel still seeps thru with the valve in the 'closed' position. I'd like to be able to have this valve give a positive seal when closed. Can I do something with the current valve or should I look for something new? Does Deere carry a good replacement or are there other places that can provide one? Something has got to be out there that provides a better seal but still looks somewhat original.
Dave K
11-22-2002 10:44:41
 Re: Can't Get Sediment Bowl Fuel Valve to Stop Flow in reply to Mike, 11-20-2002 19:12:37
I purchased an on/off gas valve at NAPA and installed it down by the carb. Screwed it into the carb and the fuel line into the valve. Works fine. Cost a couple of bucks.
Dave
Dave K
11-22-2002 10:43:37
I purchased an on/off gas valve at NAPA and installed it down by the carb. Works fine. Cost a couple of bucks.
Dave
Jim in UK
11-21-2002 02:55:36
I gave up on that two way valve many years ago. Try to get one at your local NAPA dealer. They are cheaper, and will work just as well and the customer service wants to help you rather than just get you out of the store with your older equipment.
Bob
11-21-2002 05:34:59
 Re: Re: Can't Get Sediment Bowl Fuel Valve to Stop Flow in reply to Jim in UK, 11-21-2002 02:55:36
If you're suggesting that JD isn't interesting in helping owners of antique equipment, that isn't true for ALL Deere dealerships. The parts guys at my local JD dealer have been very helpful to me.
rick
11-20-2002 19:51:05
I went thru the same thing. Deere doesnt make the two way anymore. they make a look alike but its screw in and out. about $20 at any jd dealer
